Let' get it started. Post your GPS results and comparisons.
FR935 vs F5s
FR935 vs FR920
FR935 vs FR23x
Thanks!
Three to 5% is well within the bounds of what one should reasonably expect from a wrist-worn consumer level GPS device. Did you follow the exact path along which the course was measured? Was the course measured with a calibrated wheel?
Like others, you need to align your expectations with reality.
I understand, but comparing to other runners, using older FR's, an Ambit user and iPhone user, they were +/- 50 metres in comparison, and this is checking different parkruns I do.
Also coming from a Ambit 2 and 3, it was usually very good on distance.3% to 5% is better than very good for these devices. You appear to be suggesting that the Ambit devices were better than that. Please post the tracks and associated data from these runs so that we can make the assessment too.
I'm still deciding between a F5 and FR935, I current have an F3.
My main concern is the F3 short-changes the distance I run.
I do a lot of Park Runs all of which are 5kms, and my F3 usually has me around 150 -250 meters short.
After seeing the comparisons here, looks like the FR935 compared to the F5 is also showing shorter distances....
I'm sorry but this is quoted regularly, frankly wrong, and minimizes issues that some users may be having. Manufacturers quote much larger error margins then what their devices are capable of. Even the Fenix2 (which I thought was the worst device ever) rarely created errors over 3%.
Even if you don't compare GPS measurement vs course measurement, users are savvy enough to compare identical runs.
While there are some things to teach new users about GPS limitations, good devices are usually have less then 1% error consistently.
I agree. My distances are consistently within a 1% variance, if not better. I'd be really unhappy with a 3% margin of error.
