Let' get it started. Post your GPS results and comparisons.
FR935 vs F5s
FR935 vs FR920
FR935 vs FR23x
Thanks!
I ran for the first time today with both GPS and GLONASS enabled on the 935.
The track more closely mirrors that of the V800, although I still managed to lose 0.06 miles on the 935 during a 6 mile run.
Here's a sample (blue V800, orange 935):
Don't see any issues there with those tracks. I sometimes get a 0.06 difference in 2 devices in a 6 mile run. You seem to imply though that the V800 is "perfect" and the 935 is 0.06 miles out. If so, why do you think that?
Presume given the 935 now has BLE connections that you could pair your Polar strap to the 935 if you wanted to use a HR strap.
You could also use a Garmin HR strap and likely to have better HR performance than OHR alone.
As for GPS performance, to me, it largely comes down to repeatability in the distance especially on routes you know. So if you did that run say 10 more times and the 935 was always 0.06 miles "short" of the distance you really think it is then you might think something was odd.
I've seen mention that one sec recording improves GPS performance, does this still count true for current watches like the 935? I've always left my garmin devices on smart recording and not seen any issues...
That's a common myth and unless that was stated by somebody from Garmin on the product team I would not believe it. The watch still samples at the same rate regardless of how often it records it. Of course when you look at the recorded track after things may look different depending on how many points you have recorded.
