Turn by Turn Navigation
Anyone know if you can get turn by turn navigation like on the f3 from a TCX or GPX file?
  • Too bad the course navigation does not display on the Varia Vision, that would have been awesome.
  • Yeah, good isn't it. I setup a course for an "exploring" run the other day and some might be interested in this pic https://www.instagram.com/p/BF_gCGouofB/ which gives an idea of the sort of display you get.
    Yup, it's simply brilliant! I also love how you can add a "pace" on the course creation which is then used to display an "estimated time" of completion which is actively tracked throughout the run.
    Now the fact that all the turns in the route are automatically detected and converted into vibrating alarms is what makes this whole thing work like a charm!
    I am nitpicking here but two suggestions for improvement:
    1) Add a way to disable "off route" alarms as sometimes what you find in front of you doesn't match what you planned online so you make real-time adjustments. That's my personal preference of course
    2) Change the timing of the second "turn" alarm which in my case always seem to happen a few seconds after I made the turn instead of right on or before the turn. I am not sure if this is by design but right now the second alarm acts more as a "confirmation" of the turn rather than a routing aid. If it's by design, then also give us an option to disable it as at the end of the day the watch keeps buzzing too often :-)
    Again, I am nitpicking here as I *love* the new routing functionality!
  • I think the second alert is a confirmation that you made the correct turn. I actually like that as sometimes if you get no feedback you are not sure about the turn unless you are watching the bread crumb map.
    Right, I can see how people would like this but that's why I suggested that if "it's feature, not a bug" I would prefer to give us the option to disable the second confirmation buzz because this ends up being too many buzzes for my taste :-) I am not suggesting to turn it off for good as I can see its value.
    Cool feature, can't wait to try it in the French Creek Iron Tour this weekend! Is it a documented feature of the 735?
    Answering my own question, it is documented in the 735's manual.
  • Don't see the turn by turn bit in the manual though.
    I'm having trouble figuring out how to import a track from RideWithGPS to GC as a course. There seems to be no import option for courses!!
    So I tried uploading a .tcx file from RWGPS as an activity to GC and it wouldn't work. The error said "undefined".
    Anyone have any luck creating courses in GC?
  • In GC, you can only create a course from an activity already in GC or use the course creator.
    What you tried should work in theory.
    What was the source of the TCX file however? It would need to have meaningful timestamp as well and lon/lat data.
