I’ve been having the same issue, but was able to get it fixed. Follow these steps:
Go to Settings>sensors>FP-Jabra Elite Act. Remove it. It should now only show Jabra Active Elite —no FP before it…
You have to avoid connecting the Jabras as a sensor. Say no when it asks.
Try this. Go to sensors & accessories on the watch,there're FP-Jabra Elite Act and Jabra Elite Act. Remove FP-Jabra Elite Act one.
I just got the Garmin Vivo and have the exact same problem. I can connect my Jabra elite active 65ts to the watch no problem, but as soon as I start a run and turns the GPS on, I lose connection and cannot connect the headphones. It just does a constant loops of "connected" then "disconnected". However as soon as I end the run (and assume the gps goes off), the headphones can connect again just fine.
Any hope? I got the watch specifically so I can run without having my phone and still listen to music. If there's no fix, I'm going to return the watch.
It's been a while since hearing about this issue. Assume you've updated the headphones to the latest firmware? 2.34.0 is what mine are running.
Yes headphones are updated. I actually just found a thread that said the watch also adds the headphones as a "sensor" and if you remove it from "sensors" in the settings of the watch, then it should work perfectly. I haven't tested it yet, but hopefully that's the solution. Sounds like it worked for others.
Garmin should really put in fix for it.
