hi, sorry to hear about your mishap
you are the seventh "Garmin Vivoactive 3 Music" user with the same fit file error in ten days
recording to the fit file ended abruptly without proper closure
you and other users need to call Garmin Support and tell them about your mishap
(oroszbela, 4856370, Phoenix33, 6850623, 1003180, HamShanwich)
your fit file can be structural repaired with help of Fit File Tools's section remover (without removing)
try this to be prepared for the next time
ran your fit file through Fit File Tools's section remover for you
check this file 7888.fitfiletools.zip
happy & safe sporting
Hi there. Appears my Garmin 800 may have corrupted my Ride file from today. Appreciate that this is an old topic, but wondering whether any pointers please as to how to fix? The only difference today, is that my ride was following a Garmin Connect COURSE that I downloaded to the 800 before setting off. Many thanks. Dave
Actually, appear to have found an online tool that's done the job perfectly for me : http://garmin.kiesewetter.nl/
Hi guys! I'm desperate, I have done my first triathlon race and it was saved on Garmin fenix 5. I can see it with pulse, distance, maps etc. on my watch, but it appears as move IQ activity on connect. I did try to upload it manually, but it says that .fit file is not supported. I think it is corrupted. any solutions how I can repair it? I tried to use one of the online tools (http://garmin.kiesewetter.nl/), but it wouldn't accept the file. I have a Mac so cant use FFRT. Would be grateful if someone could run this file.
any help is appreciated. thanks so much
Online tool looks useless as it doesn't recognise the file and returns some error, asking to repair manually. But how to open a .fit file on my PC & repair manually?
Hi there, I've had the same problem with a corrupted file. I've tried fixing it using some of the recommended online tools but that hasn't worked. Would anyone be able to have a look at it? I'll leave the fit file here in case: B74B4417.FIT.zip
Thanks very much if you are able to help.
This will work - B74B4417-fixed.fit
Some suggestions to help minimize the occurrence of corrupt fit files:
Error Occurs When Manually Uploading Activity Data to Garmin Connect
Thanks so much for this and for the suggestions of how to avoid corrupt files, that's really helpful.
2161.2021-10-31-06-04-23.fit.zip
Hi legends. Can anyone help sort this file out? Won’t upload to Garmin/ strava ( yet oddly works when I upload to today’s plan)
any help would be amazing - think I set some records!
martin
