since the 100% ROLL OUT ...
has anybody some experience about it?
in the change log is nothing to find
regarding battery drain ???
is it solved?
is it solved?
This software is now live for all users.
First ride today. Excellent- no dropping of any connections (BT phone, ant+ HR/Power/ Di2).
3:45 mins and 40% battery used (60%remaining). It was steady through the ride at 11% per hour.
I’m happy with…
To revert to 11.20:
Find and download Edge820_1120.gcd on the http://gawisp.com/perry/edge/ website.
Rename the file to gupdate.gcd and copy it to the Garmin directory on your 820. There likely will already…
The software is on a phased roll-out. You may not be able to get it until it does to 100% depending on your unit ID.
Is there a schedule for when that will be?
Nick
I don't have access to that information, but based on prior phased roll outs they typically span a few days if there are no major problems reported.
I've not seen anything negative about build 12.50 on the forum so I would expect Garmin to push it to a full release early in the week.
Thanks aweatherall. It would be good to know as I prefer not to update just before a big ride.
