Corrupt Fit file
My son did his first road race ever yesterday and was using an Edge 820. I believe that his 820 crashed right after the race and as a result his .fit file seems to be corrupt. Is there anyone that can repair it for me?
I probably wouldn't care so much about this if this wasn't his first race ever.
On a side note, his 820 seems to be crashing a lot so I suppose I'll be calling Garmin support.
  • Not sure if corrupt or missing
    Edge 820 locked up on me while recording this weekend and had to be hard-reset. It looks like it ate about 30 miles of my recording in the process. Any way to get that back, or am I just out of luck?
    Here's the file:
    hi qrohlf,
    Unfortunately that hard-reset has also deleted the data for that 30miles. Without that data, there is nothing that can be done.
    Only thing I can suggest is that if it happens again, look at updating to the latest firmware and probably the easier one, from the lock up location, save the file and start a new one as two individual files are easily joined together.
    cheers
    Mike
    hi Mads,
    Give this file a try.
    cheers
    Mike
    Could someone please repair this fit file, Thanks, Danny
    hi DannerJoe,
    You had a small amount of corrupted data near the end of your swim and leading into T1 so the distance/time may not be quite correct.
    cheers
    Mike
    Hey kiwimtnbkr, thanks for the effort! But that is not my activity. I live in Kentucky USA and the file you attached is from Nice France.....could my file be that corrupt?
    Also, I use a garmin 820
    Hi DannerJoe,
    Not too sure how I managed to do that BUT give this file a try.
    cheers
    Mike
    Thanks again kiwimtnbiker! While that is a section of one of my rides, it is not the ride I did on Wednesday, August the 2nd. While saving my ride, like I always do, my Garmin apparently discarded the ride. I was able to recover the ride using "Recuva" but I could not get the "fit file repair" tool to work. I really do appreciate your efforts tho! Thank you for trying!
    Hello,
    Could someone try a repair on this file? I accidentally discarded a ride on my EDGE 820, but managed to retrieve the FIT file using one of those undelete utilities. It seems like there's a bit of corruption though.
    Thanks,
    Tom
    hi Tom,
    Well over 50% of your file was corrupted and unsalvageable.
    This file contains what I have been able to recover.
    cheers
    Mike
