Edge 520 software version 3.0 available but ...
Version 3.0 is shown available on the Garmin website but Garmin Express does not think there is any update. What gives?
http://www8.garmin.com/support/download_details.jsp?id=9270
Change History
Changes made from version 2.30 to 3.00:
Added support for Varia Smart Bike Lights. Now you can form a network of lights including head lights, tail lights, and a rearview radar tail light.
Added support for sensor software updates
Added the ability to edit crank length for PowerTap P1 pedals
Added dynamic zooming while displaying the elevation graph during an activity
Added a Percent Effort option for adjusting the virtual partner speed when following a course
Added a preview of an incoming text to smart notifications
Updated the FTP test to include setting a goal and accepting or declining the test results
Fixed an issue preventing accurate data from being displayed with an HRM-Run
Fixed an issue preventing the elevation graph from being drawn correctly
Fixed an issue where segments would randomly not start
Fixed an issue where courses would sometimes not start at a point along the course but away from the start location
Improved device performance with many segments loaded
Improved device performance while navigating through the list of courses
Improved stability of device-to-device transfers
Various fixes for general improvements to stability and performance
  • I plugged mine in yesterday and am fairly certain Garmin Express said I was up to date with 3.0 but the 520 still indicates 2.3.
    I'll wait a few days and see if it gets updated automatically. Can it get the updates wirelessly?
    https://forums.garmin.com/showthread.php?326017-Edge-520-software-version-3-0-available-but&p=733847#post733847
  • The GE interface can be a little confusing. Because it automatically downloads any updates to your device what it is really showing is the latest available update as it assumes that the update it has just downloaded will install correctly. For some reason it does not sound like it did.
    You can manually install the update by copying the Edge520_300.gcd file from this location in to the Garmin folder on the Edge and then renaming the file to gupdate.gcd. The Edge should then apply the update after you disconnect it from the PC.
    Anybody can confirm than grade calculation (% of ascend) is improved comparing with previous firmware version (2.3)?? Note than with 2.3 version this calculation has a noticeable delay when shows the instant grade.
    Thanks in advance.
    No noticeable change in the handling of altitude with this update, the lag is still obviously there and way behind the 500 (I'm still riding with both units for comparisons) consequently the gradient calculations are still lagging too.
    I have yet to complete a circular ride where the 520 reports anything close to the same ascent and descent figures - the descent is always far less than the ascent - which again points to slow altitude calculations on the 520. The 500 is usually within a couple of metres which is acceptable allowing for air pressure changes.
    Oh well, back to waiting for the next update...
  • Hi!
    I live in Europe.
    I bought 520 Taiwan(ebay). I can not use firmware 3.0(I use firmware 2.60). Why?
    Is there any solution?
    Thanks!
  • Disappointingly, the version 3.0 does not fix the connectivity issue with the Wahoo Tickr HRM. It is still taking a very long time to do the initial pairing and even when paired, it's only connecting, very briefly, on rare occasions.
    Also the version 3.0 firmware does not resolve the pairing issue of BLE_Edge_520 (for call/text notification) with iPhone 6s.
    Found out from Wahoo Fitness that the Wahoo TICKR HRM is not compatible with the Edge 520 and 1000 because they are using different ANT+ protocol. The Wahoo TICKR Run and TICKR X are compatible though.
    Guys, not sure the above is correct. I've been using a TICKR (standard - not run or x) from day 1 with the 520 without any issues. I have two TICKR HR monitors, in fact... Have yet to try with the 3.0 firmware - I seriously hope they didn't screw it up!
    I tried replying but it doesn't seem to be showing up. Anyway, I'm not sure the above is correct. I have two Wahoo TICKR (standard, not Run or X) which have worked flawlessly with my 520 from day 1.
    I haven't tried the 3.0 software yet... fingers crossed that it won't mess up my HRMs.
  • I tried replying but it doesn't seem to be showing up. Anyway, I'm not sure the above is correct. I have two Wahoo TICKR (standard, not Run or X) which have worked flawlessly with my 520 from day 1.
    Same here, and it still works OK with 3.0
    This post may seem out of place on this forum but I want to say THANKS! There's not much positivity in most of these posts., Update went automatically no problem, I then deleted the default profiles that reinstalled themselves to leave me with my original custom ones, and everything seems to be working fine - elevation profile, courses, turn points & warnings, phone messages. Hope i'm not in the minority.
    Yep! Same here. All the nagging issues I had seem to be addressed. Especially the BT syncing with my iPhone 6. Everything connects and communicates as advertised!
    The only problem I've found is that now riders know when one of my KOMs are coming up. I've lost TWO already! Really?!! Sheesh... guess I just have to train harder and get them back! LOL
    Thanks, Garmin!
    :cool:
  • Hi!
    I live in Europe.
    Thanks!
    The regional variants of the Edge have their own product numbers and dedicated software. You cannot convert a unit from one region to another. These units are not really meant to be sold outside of that region as they have been enhanced/modified for that region, but some sellers will sell outside of the targeted region. Typically features released in the non-regional model get pulled in to the regional builds at a later date, but I don't know how quickly that will be.
