Anybody the same?
Girlfriend with 9.5 has the half HM.
Hello All,
I wanted to let you know we are aware of this problem and working on a resolution. I apologize for any inconvenience this has caused and I will provide an update or resolution when one is available…
Fix is released with firmware 10.20.
forums.garmin.com/.../new-edge-1030-and-edge-1030-bontrager-version-10-20-now-available
Can anyone tell me what's the way to report this to Garmin?
Or has it already been done?
Same here. I sent a e-mail to Garmin tech support.
their answer was meaningless.
connect your phone again
do soft restart
do hard restart
check is there are new updates
they said nothing about this problem…
Hi, as I've written before, you get the elevation error when your ride is near flat or moderate climbing/descending hills. If you climb steadily then return to your place by the same route (no ups and dows of few meters every time), the elevation is correcly computed. The issue is most probably due to a bug in taking into account those little ups and downs.
hello, this weekend i followed a track I downloaded.
As a surprise I ended the route with the same elevation as the track. And in every mountain climb, it added the elevation that climb-pro was showing.
Could be that Firmware 10 only fails with the calculation if you are not following a track and riding freely?
nope
made 2 times the same course of 50 km / 280 d+ (so : not realy flat, and now it's 380 d+), and this sunday, we were 3 guys riding together : the one with a old edge 810 = 1170 d+, my 1030 = 1380 d+ and the 1030 of the last one = 1650 d+ (and damn there were some climbs ...)
Je souhaite savoir comment vous faites pour avoir la mise à jour officiel de la mise à jour !
Quand je le branche à l'ordinateur garmin connect me dit que je suis à jour mais c'est la version 10.00 et non 10.20
J'aimerais éviter de faire la manipe du fichier zip à incorporer personnellement
I did it downloading the file because it was not showing in Garnin Connect either. It worked following the procedure and the 1030 is showing the new version, but if I plug it back to my computer, Garmin Connect still show that the version is at 10.00 after synchronisation....I will see later after my ride if the altitude problem is no longer there.
