24 hours, and no one dipped their toe yet ? I do hope the inability to power up is of of the the "fixed various stabilization issues" that were fixed !
hangs on startup, fires up then stuck with "Checking" at status line
Initially everything appeared OK. However like with the 9.68 Beta. On power-up the edge will lock up if WiFi & BT are both enabled. Disable one of them & the Edge starts fine
I also have the update v10 on my edge and it definitely performs better than v9.5. Screen response time is a lot better.
It seems that the descriptions of the updates for Edge1030 and 1030PLUS have been mixed up.
-Added a toggle for MTB map theme
There are no MTB themes for normal 1030 for example - only Edge 1030PLUS!
Edge 1030PLUS got a GPS update.
Does the 1030 plus use a different GPS chipset?
As far as I can tell - yes. But I have my knowledge only from various publications.
Edge 1030: Mediatek MT6630
Edge 1030 PLUS: „the new Sony GPS chip“ - that‘s what have read.
I recall seeing a reference to new GPS firmware in the post announcing firmware 10 but that reference is no longer there.
I've been running 2.51 beta GPS firmware on my 1030 for the past year without any problems. Available here: https://www8.garmin.com/support/download_details.jsp?id=15023 (and there doesn't seem to have been a further update in the year since this version was released)...
Same here, locks up mostly and sometimes doesn't.... boot up can take minutes. tried the 'turn off phone BT' then it works more 'normally'. turned phone BT back on and so far no lock up.....
Disable either Bluetooth or WiFi, then it'll start. Already mentioned in this thread, but keep telling Garmin!
Not really noticing progress in v10:
Device still crashes if I run a course imported with Komoot IQ app
Activating mass storage mode is still a PITA on a Mac
Often, map view in turn notifications for upcoming roundabouts makes no sense; has always been that way, giving up hope
Recalculation of a route takes ages and meanwhile the map view screen freezes and I can^t see where I am going
Response is sluggish sometime
