New Edge 1030 Public Beta 8.06 Now Available
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found here.
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 8.00 to 8.06:
  • Added support for Connect IQ 3.1.
  • Added support to control Garmin inReach remotely.
  • Made improvements to indoor cycling user experience.
    - Improved smart trainer discovery and initial setup experience when using an Indoor activity profile.
    - Improved the Follow Course experience by enabling UI (map, ClimbPro, Elevation, etc) and data recording from the simulated course.
    - Made improvements to smart trainer sensor calibration.
  • Made improvements to Workout user experience.
    - Added FTP line to workout comparison displays.
    - Allow graphical workout data fields to be configured on regular data screens.
    - Improved the display for open steps on the workout comparison graph.
  • Made improvements to the ClimbPro user experience.
    - Made ClimbPro available for navigation to a location and for round-trip courses.
    - Added a setting in the ClimbPro data screen setup to specify which climbs should be detected (All, Medium/Large, Large Only).
    - Removed the ClimbPro page from the timer loop if there are no climbs left in the ride.
  • Made improvements to the Segment user experience.
    - Fixed an issue where segments with slashes in the name would not be processed and would create subfolders on the file system.
    - Fixed an issue where the segment leader could get reset during a sync.
    - Added setting in the Segments menu to set a Default Leader Priority, which allows the user to set a default leader to apply to all segments.
  • Fixed an issue where the GPS track locked to the road inaccuarately.
  • Improved Firstbeat heat acclimation by utilizing weather forecasts.
  • Fixed an issue where Battery Save Mode could stop working mid-ride.
  • Show the jump prompt for each jump in cases where there are multiple jumps in a row.
  • Fixed issues with the heart rate graph data field.
  • Fixed an issue that caused Auto Detect Max HR to always be enabled.
  • Improved the y-scaling on the elevation profile.
  • Added directional arrows for round trip courses.
  • Fixed cosmetic issues with Extended Display mode.
  • Added additional info to the nutrition/hydration settings page
  • Turned backlight on when the user laps or there is an autolap during an activity
  • Automatically sized the text in the elevation data field.
  • Improved overall device stability by fixing crashes and freezes.
  • Great, Garmin!
    Please improve the contrast level of BirdsEye (or custom maps); or possibly a control screen to adjust the screen contrast. I say this because on the computer screen, the maps are quite sharp, but on the Edge 1030 the color is poorly saturated. Grateful once again.
  • I took the risk and updated to 8.06. So far nothing wrong but have only played with it indoor. It connect ok with WAHOO CORE trainer and now I can use the cadence that its coming from the trainer.
    CLIMB PRO looks better...
    The list of changes is too long and there is stuff there that I did not even know what it is or how to use.
  • The Edge devices use a screen technology that is very low power (needed since it ON all the time) and perform very well in direct sunshine (needed since as you ride you don't control the sunlight direction). However that technology is not good at rendering imagery i.e. it has limited constrast and not so many colours to use. It is not designed to do what you are looking for, BirdsEye being more of a Outdoor GPS unit feature. I have never seen BirdsEye used on the Edge. The Edge is not really designed to work that way. There is no software change that can compensate for limitations of the hardware. For most cyclists Garmin chose the right tradeoffs.
    Great, Garmin!
  • Unable to sync with Garmin Connect APP Android. Iq apps don't work anymore.  (eg. Ride with GPS keeps loading)
    I can confirm that with this update the Ride with GPS App no longer works & sits at the Loading screen.
    What I don't know is if it's the F/W update itself or the Ride with GPS App is not compatible with the CIQ 3.1 update in this beta
  • Yes lights are connected fine
  • I had a ride with 8.06 and all was good for me today.
  • I've had this happen on previous firmware updates and found deleting BT profiles and reconnecting from GCM fixed it.
  • Thanks for the suggestion. I have tried that but it didn't fix the issue.
    I'm pretty sure it's something that has changed in CIQ 3.1 that is causing communication issues between some apps that access services via a paired mobile device. I've been testing the Grouteloader, Gimporter & IQ Map Receiver apps and although they do work; where under f/w 8.0 they would take less than a minute to download a route to my edge; under f/w 8.06/8.07 they're taking somewhere in the region of 10 minutes to download the same route. In fact as I have auto sleep enabled on my edge if I don't keep tapping the screen every now and then the edge will go to sleep before the route downloads. Something, which previously i wouldn't need to do
  • first check on V8.06  ==> Climb Pro doesn't work for round-trip >100km. If you save the round-trip as course and reload it...then it's working.
    I've sent the "Feedback Reporting Form" with the bug to GARMIN
    Guido
    0 Former Member in reply to hotdogpartysausage
    I just tested Gimporter under 8.07, and it seemed to operate fairly normally - took 20-30 seconds to download a course from my phone to the 1030.
