Not sure if this is to do with v7.50 of the Edge 1030 firmware or v1.05 of the ConnectIQ TyreWiz app, but something bad happened within the past month. If I stopped long enough and the TyreWiz sensors went into sleep mode, they would just drop out and never re-connect. For the past six months, everything worked if you rebooted the Edge 1030 _after_ the sensors went to sleep and woke back up. Now, when I start a ride, the TyreWiz sensors don't connect at all until I've ridden for about ten minutes and then reboot the Edge 1030.
It's also annoying that you MUST use two data fields for both sensors and they're using a weird font. It would be much better to just add front and rear tire pressure settings as individual fields. Isn't this an option with the ConnectIQ API?
Is Garmin going to add native support for these at some point? Clearly, there's some sort of problem with ConnectIQ or Quarq's ConnectIQ app itself. It has never worked as flawlessly as the Edge 1030 connecting to power meters, HRMs, etc.
