Too big fitfile garmin 1030
Yesterday i drive route and same time navigating that. when i stopped and saving it, Garmin 1030 freezing and not send that to Garmin connect or Strava. fitfile was 158 Mt..
Does someone help me and fix that.? I only need time, kilometers, route, elevation calories and maybe segments.
I think that Navigate corrupted that file.
Antti,
From Finland
https://drive.google.com/file/d/18ONqbkSz5vE6WSePRhnBI0slSb_7N3Bv/view?usp=sharing
    same problem as described here...garmin-edge-1030-fit-file-to-large
    Also contact Garmin Support and tell them about your mishap.
    these are blocks of 999 data records that are repeated and repeated, creating a huge file
    the other user repeat was 255 data records
    Data,14,unknown,unknown,"928991852",,unknown,"733676928",,unknown,"284196160",,unknown,"998",,unknown,"2"
    Data,14,unknown,unknown,"928991852",,unknown,"733705234",,unknown,"284124263",,unknown,"13",,unknown,"0"
    Data,14,unknown,unknown,"928991853",,unknown,"0",,unknown,"1",
    Data,14,unknown,unknown,"928991854",,unknown,"733705928",,unknown,"284122158",,unknown,"15",,unknown,"0"
    Data,13,record,timestamp,"928991855",s,position_lat,"733705823",semicircles,position_long,"284122525",semicircles,distance,"620.53",m,altitude,"102.79999999999995",m,speed,"4.805",m/s,unknown,"3021",,unknown,"192",,heart_rate,"114",bpm,temperature,"15",C,enhanced_altitude,"102.79999999999995",m,enhanced_speed,"4.805",m/s,,,
    Data,14,unknown,unknown,"928991855",,unknown,"3",,unknown,"1",
    Data,14,unknown,unknown,"928991855",,unknown,"733678016",,unknown,"284194176",,unknown,"0",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733678016",,unknown,"284194176",,unknown,"1",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733679680",,unknown,"284188992",,unknown,"2",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733686784",,unknown,"284180928",,unknown,"3",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733691904",,unknown,"284167424",,unknown,"4",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733710272",,unknown,"284107392",,unknown,"5",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733712960",,unknown,"284087936",,unknown,"6",,unknown,"2"
    filled with data from 7 - 992
    Data,14,unknown,unknown,"928991856",,unknown,"736160896",,unknown,"284504000",,unknown,"993",,unknown,"2"
    Data,14,unknown,unknown,"928991856",,unknown,"736162688",,unknown,"284482560",,unknown,"994",,unknown,"2"
    Data,14,unknown,unknown,"928991856",,unknown,"736154816",,unknown,"284456000",,unknown,"995",,unknown,"2"
    Data,14,unknown,unknown,"928991856",,unknown,"736152256",,unknown,"284436800",,unknown,"996",,unknown,"2"
    Data,14,unknown,unknown,"928991856",,unknown,"736148992",,unknown,"284431232",,unknown,"997",,unknown,"2"
    Data,14,unknown,unknown,"928991856",,unknown,"733676928",,unknown,"284196160",,unknown,"998",,unknown,"2"
    Data,14,unknown,unknown,"928991855",,unknown,"733706128",,unknown,"284121418",,unknown,"13",,unknown,"0"
    Data,14,unknown,unknown,"928991856",,unknown,"0",,unknown,"1",
    Data,13,record,timestamp,"928991857",s,position_lat,"733706345",semicircles,position_long,"284120670",semicircles,distance,"630.14",m,altitude,"103.39999999999998",m,speed,"4.264",m/s,unknown,"3025",,unknown,"195",,heart_rate,"115",bpm,temperature,"15",C,enhanced_altitude,"103.39999999999998",m,enhanced_speed,"4.264",m/s,,,
    Data,14,unknown,unknown,"928991857",,unknown,"733706728",,unknown,"284119520",,unknown,"15",,unknown,"0"
    Data,14,unknown,unknown,"928991858",,unknown,"3",,unknown,"1",
    Data,14,unknown,unknown,"928991858",,unknown,"733678016",,unknown,"284194176",,unknown,"0",,unknown,"2"
    huge fit file repaired with FitFileRepairTool
    Antti L-H_E1030_large_pirkka-fixed.zip
    0 Former Member over 6 years ago in reply to Former Member
    Thanks very much! You are amazing!
    FitFileRepairTool says no problem Wink
    do not forget to contact Garmin Support
