Hello, I'm opening a new Thread because the other one was closed, not sure why as it could be helpfull for both, users that have the same issue and Garmin to investigate the case.
As I said I have my third unit. This last one comes with 86.04 Screen version, so from the garmin forums this will not present the previous "delamination" screen issue.
But there is a random issue with the "screen touchs" that does not happens with old screen. Those are random bugs in detecting screen "touches" , and the obvious answer is that does not work well.
As the other thread open by ztbishop describes:
Running the touchscreen test reveals the errors. The more important for me is that those errors are *random*, what means that either is very very slow to detect "touches" sometimes on some parts of the screen, or on others sometimes some touches or gestures does not work at all. As an example Yesterday I was unable to open the top-down menu to access to settings and I have to restart de device for get it working again, but after reboot works ok. There is some point that almost allways fail for me, and is when you have finish your training. After stopping and recording the session, the resume screen appears and I was not able to push "X" or "Ok, verification mark" after about 10-15 seconds, and this is maintaning the finger on the screen for 3 seconds aprox.
So as a resume, sometimes in some screens touches works, whether some others on the exact same screens in other moment in time or other screens doesn't.The nature of the bug is random.
As this issue does not allways affect to same part of the screen, I think is not related with the screen itself (the touch layer of the screen), and seems much more related to:
1. the Screen Driver Itself (perhaps the driver change with the screen, better Garmin to confirm this point)
2. Or some ramdom communication issues (sould be somewhere in the devive logs) between the motherboard and the new screen.
3. There is a third posiblitiy that is that the Screen itself is maltfunctioning, what is also even possible....
On my Third device (second replacement), I do not want to change it again unless the third screen (new one 86.04) was faulty again...
@Garmin, could you have a look please.
@People, please those with new screens with this kind of vehaviour add posts to this thread to provide more information to help Garmin to pin point better what the issue is to help them solve it (if possible).
Regards,
Manuel.
