Battery losing power overnight in sleep mode
My 1030 is losing power (65% to 2%) in sleep mode, overnight. Should this be, and what can I do to fix it?
  • I would like to know, too.
  • This is definitely abnormal. Has this always occurred or is this a new development? Also, are you manually putting the device into sleep mode, or are you letting the device automatically do this after your activities?
  • This was 2 years ago. Can’t even remember the problem. Not happening anymore and I’ve updated to the 1030 Plus, but now I always turn it off when not riding to prevent loss of power. Works great.
  • You may be able to help me. I purchased a 1030 in April of this year. And several times, this happens:
    I'm on a ride, and I pause for a breather/rest. I pause the ride pressing the lower-right button, and then I press the power button to put it in sleep mode.
    After a few minutes, I press power again to resume the ride, and it never powers back on. I try pressing the power many times, try holding it for a few seconds, and it remains off and unresposive.
    This has happened when the battery was at about 40%, yesterday it happened when it was 55%.
    Then I feel like my device is either dead or the battery is a lemon and needs to be replaced.
    But I just read on here, that this is called a device lock up and that holding the power button for 10 or 15 seconds will unlock it. And when I tried that, it worked and turned on again finally. I had it plugged in at the time too, thinking that charging it would wake it up. But charging did not wake it up or show any info until I pressed the power button for a while.
    Is this a known bug? This lock up? Is it a feature? Any other posts or FAQs about this? It's not in the Garmin manual.
    It's been occurring on mine intermittently since the 10.0 pre-release with it being powered off or in sleep mode.   So far, 10.26 hasn't done it, and I keep checking it pretty often now.
