Why is it not possible to add a map screen in ice skating?
If you choose outdoor then it should enable GPS
Sure, but I want maps as well!
it will only work if you have the GPS enabled. Double check in the activity settings
That's the issue, there's no way to add a map page in the activity settings
Ahhhh! I misunderstood you. I thought you want to see the map in Garmin Connect.
After you choose Outdoor long press the left-middle button, then go to Ice Skating settings > Data screens > Add new ....
I know, but there's no map to select there
Try your luck: https://www.garmin.com/en-US/forms/ideas/
If I had to guess, it's partly because certain activities like Ice Skating and Basketball are more or less clones of Cardio, except with even fewer options. (Ofc the major difference is in the activity/sport type that gets saved to the FIT file and displayed in Connect).
Cardio also doesn't allow you to add a map screen out of the box, although ironically it lets you follow a course, at which point a map screen will of course be displayed. (Ice Skating doesn't support following a course).
Iow, it's just a fairly arbitrary restriction that's probably meant to simplify things. From a practical POV, they probably figure you don't need a map while you ice skate (or play basketball) because you're not really going anywhere during those activities.
I guess they’ve never skated on big lakes during the winter then… Funny that the qustion about outdoors/indoors is there, and that a track is saved if selecting the first one, but not possible to add a map
