Basic EGR trouble shooting of 965 + Kickr Core WORKOUTS
This one has me stumped, and I've done due diligence searches.
It's basic, I have a FR965 and want to start coached Indoor Bike Workouts, I also have a KICKR Wahoo Core that's been upgraded to the latest firmware (1.5.36). I have no other devices / apps that I intend to use in tandem.
I CAN:
 - Pair the Smart Trainer
 - Hop on and start pedaling to get speed, cadence, and power
 - Set the resistance manually from the Smart Trainer Options
For the life of me, I CANNOT: have the watch EGR adjust the resistance for me to target specific HR & Power during a workout.
- I have no other devices / apps that would have connected to ANT+ FE-C
- Bluetooth light is blinking periodically, ie there is no active blue tooth connections
I've repeatedly restarted watch, trainer, their pairing... each time I start the workout resistance shows 0 (from new pairing) and doesn't move during warmup, or in high intensity intervals after warm up...
There must be something simple I'm missing Fingers crossedFingers crossed, Mike
  • Me i'm using MyWhoosh ( swift like but free) For workouts so it controls the  trainer and watch only tracks the workout.
    But from the watch you can set resistance or power as well( not both as they conflict with each other). You can for example create a workout in GC with your desired settings/structure and push to the watch and start from there. Or from watch you can set / change resistance during a workout via long press on middle button -> Smart Trainer Options -> Set Power.
  • Yes, my experience is with Zwift, and I know when the app controls the the trainer there is a VERY marked difference in resistance between warmup, intervals, and cooldown, eg where I'm effectively just free spinning my legs in cooldown... All while never leaving the same "middle" gear on the bike.
    When I run a GC Workout suggested by GC Cycling Coach (Anaerobic 30min warmup, 4x interval, and cooldown), the watch data screen shows resistance 0 the whole time (is that correct, or indication something is not working?)... I mean I can vary the effort I put it, without changing gears, and approximately match what's asked of my by the GC Coach/Workout, but it makes for a very different experience than Zwift was <shrug>.
  • I would have to check on next workout but I think resistace value on the watch won’t move. I don’t have it on my data fields I read just the power value
  • Piotrze, yes, very curious what your data screen shows at bottom when you're doing a workout in EGR!
    I'm just going to keep rolling with Garmin cycling coach workouts, leave bike in middle-middle gear and see how it goes!
    Point is my experience with zwift was different, recovery would automatically drop the trainer to very low setting, night and day pedal effort change, and I could easily drop HR.
    Yes, I can get the night and day pedal effort change in manually setting resistance, but that is not EGR.
  • SOLVED: I don't know how I missed this, and I wish it weren't the default, the issues was that the Cycling Workout Target was set to Heart Rate. Set this way, I don't know if the watch was doing anything to the ANT+ FE-C controls, but simply depending on me to pedal faster / slower, change gears / resistance to reach the desired heart rate. This felt quite odd, especially when I was to get my HR into high rates for short 20s intervals... with the watch harassing me about my HR not being high enough, then right away about being low.
    Prompted by that I switched to Power as the workout target... and this is the trainer cycling nirvana i was looking for: I've got the tunes pumping, pedaling at whatever music bpm, and the watch + trainer are adjusting resistance to hit the target power! BRILLIANT
    Now... if I could only figure out how to select / redo one of the cycling workouts (Tempo, Sprint, Anearobic) outside of my Cycling Coach schedule... <scratching head>
  • przepraszam, I had my bike unavailable for past few weeks. I just did a test but i see you solved it.
    For 'redo' i think you can't but you could create your own workout on Garmin Connect and the push it to your watch it's pretty easy.
    as alternative you could select one of future workouts ( for upcoming week).
