Hi all, my Forerunner 965 has recently started to record wildly incorrect elevation data on runs - see example in attached image on 7k run today and correct elevation data after fixing in Strava.
I have calibrated the altimeter several times, including just before runs, but the issue continues.
I've seen in posts that others have had a similar issue, but not sure if it is a component failure, or recent software failure?
Anyone else having the same issue - and any tips to resolve?
Thank you in advance.
