Hi. How do i remove the Garmin "Daily Suggestions" from my 965?
I have removed my primary race on Garmin and replaced it with another race on the same day.
Now my Daily Suggestions still use the old race for suggestions.
thanks
I would try this:
Remove the races from calendar (and ensure they are not still on the watch as sometimes happens), or maybe try make them all "no priority" as then they don't get on the watch , only primary and secondary do that
Soft reset watch
Maybe toggle receive DSW off and on also
The see how the base (no race ) DSW look
Then add a race
Thank you for the advice.
I have removed all upcoming races from the calendar on Garmin Connect, but an old primary race I deleted some time ago is still showing on my Garmin watch under the Race Calendar and as my primary DSW. As a result, I can no longer change the priority.
How can I view the default DSW (with no race set)?
Also, how do I perform a soft reset on the 965?
The best way to get rid of that old race hanging is a full reset, sometimes they just don't delete properly. Before you do this , read this link.
Soft reset = hold in top left button until watch shuts down completely
You see the DSW under activity (Like running) then Training , but if you have a race in the watch I think it uses that,
I've reset my watch a few times fully with these races not deleting.
