Tried using the golf functionality on my watch for the first time.
When I start the activity, and select the golf course, it starts loading for a second or two, and then it just reboots the watch.
Update as of September 18th, 2024:
Version 20.29 is now available, and once installed...see if this helps to correct the issue. If you continue have the concern after verifying the new version is installed…
All,
Thank you for your patience with this investigation . If 20.29 did not resolve this disruption for you, please try resetting the Golf activity settings.
You can back up your activity settings by following…
All,
Thank you for sharing your updates. If software version 20.31 did not resolve the crash for you, please start a new thread or contact Product Support directly!
Same thing here, since the update the golf app crashes every time. Can we have access to the older version of the software to get the functionality of our watches back?
Please check again, it should be available!
1. Happened to me for last week or so with 20.29.
2. Happened at two courses I’ve been to.
3. Yes.
4. USA.
Behavior is as follows: Start golf app on Forerunner 965. GPS loads, it displays “Welcome to <Golf Course>” without the option to select course (as expected). It loads, and then the watch crashes and resets.
I just attempted to reproduce behavior from home, and it now gives me an option to select course. I selected, it showed “Loading course” then crashed. I have a video of behavior.
Hi,
any update on that problem?
I bought this expensive watch to play golf. And now, can not even load any course. It crashes each time. I managed to play 2 games 3 months ago and was working (not fine.. because the yardage is inaccurate) but was able to play.
Now, its just a useless device for golf since an update somewhere in early september. Try to force an update 2 weeks ago like you suggested.
but it didnt help. Still crashing when I pick a golf course. (Reboot) and tried 4 differents golf courses.
near montreal, Quebec, Canada
Hi, I have a Forerunner and since updating to the latest software to version 20.29 my golf app does not work on the watch. When i select the course i want to play the watch tries to load the course and then crashes and restarts. I have tried this with multiple course, have disconnected my watch from the apps and reloaded etc.
I see form the forums that this issue is happening with various models.
Please confirm the remedy asap as this is the function i use most on my watch.
Thanks.
