Tried using the golf functionality on my watch for the first time.
When I start the activity, and select the golf course, it starts loading for a second or two, and then it just reboots the watch.
Update as of September 18th, 2024:
Version 20.29 is now available, and once installed...see if this helps to correct the issue. If you continue have the concern after verifying the new version is installed…
All,
Thank you for sharing your updates. If software version 20.31 did not resolve the crash for you, please start a new thread or contact Product Support directly!
All,
Thank you for your patience with this investigation . If 20.29 did not resolve this disruption for you, please try resetting the Golf activity settings.
You can back up your activity settings by following…
Same thing here, since the update the golf app crashes every time. Can we have access to the older version of the software to get the functionality of our watches back?
Please check again, it should be available!
Update 20.31 fixed it! Thanks!
All,
