I have f965, I updated it to the new version 18.27. I turned off Pulse Ox and turned off allway display. I fully charged the battery last night and this morning it was at 58%. Does anyone have the same error?
I had a similar issue, and it was weird. I had changed an option on the watch, set the default setting for GPS to "auto select" I mean it was already set to that in the running options, but I decided to…
I have this same issue with my FR955
I havent changed a single setting and since the last update I’ve gone from charging once a week to losing at least 30% daily. Same usage pattern and settings…
Not ideal - so how do we go about solving or dealing with this battery drain issue? It's 100% not something that I've tweaked or changed, as my watch has remained unchanged for months now in terms of settings…
I think (but I'm not 100% sure) it wasn't flashing 24/7 before the last firmware update. If I am right, then whatever change causes it to be flashing all day and night is probably the reason of the higher battery usage since the FW upgrade. But maybe I'm just imagining things. I think a few months ago it was only flashing occasionally and when I was in an activity or the HR widget.
Maybe if someone still with older FW reads this can confirm this? If you have a FW less than 18.27, please post here a: the FW version, b: whether the green LED is always flashing when you set the Menu > Health & Wellness > Wrist Heart Rate > Status to "Auto"
If you have 24/7 heart rate monitoring on (the setting on auto) it has/will always flash or be lit depending on situation. It will then only go dark a while after you take the watch off your wrist.
edit: if you’re talking about activities with a chest strap, you can make it turn off by setting ”source switching” to off
I logged my issue with Garmin via email and today got the response and exchange process. I have the 955 Solar (although I've posted in various forums where the same issue has been) and it's still in warranty (just, I think.... bought it when it was first released). Refurbished model to be shipped once I send this one back. No questions from Garmin regarding the issue, only what I had posted in my original email - which was quite a short and sharp description of the issue and the steps I had done.
