I have f965, I updated it to the new version 18.27. I turned off Pulse Ox and turned off allway display. I fully charged the battery last night and this morning it was at 58%. Does anyone have the same error?
I had a similar issue, and it was weird. I had changed an option on the watch, set the default setting for GPS to "auto select" I mean it was already set to that in the running options, but I decided to…
I have this same issue with my FR955
I havent changed a single setting and since the last update I’ve gone from charging once a week to losing at least 30% daily. Same usage pattern and settings…
Not ideal - so how do we go about solving or dealing with this battery drain issue? It's 100% not something that I've tweaked or changed, as my watch has remained unchanged for months now in terms of settings…
No, scheduled sleep hours, but under settings/system/sleep mode you can activate battery saver
And battery saver is defined under settings/power management(?)/power saver(?)/change
Thank you, I'm going to try that now since it's automatic.
Good luck!
And also if you have the option to connect the watch to a computer, and check if there are any files in the remotesw and newfiles folders. If I understand things right they should normally be empty, or there is some kind of install or import in progress...
where is Garmin-Sierra could you please look into this ?
I'm curious:
1. does the green LED flash all the time? For me it does, and I can't find any way to turn it on during the day (when I'm not in an activity or the HR widget).
2. do you remember if this was always the case? I'm pretty confident that this started to be always flashing with the same FW update that started to drain the battery twice as fast (aka IMHO the reason for the battery drain is the always flashing LED, but Garmin support just don't get it)
Wrist Heart Rate:
Status: Auto (when it's OFF then the green LED isn't flashing, but when I switch it back to auto, then it starts - in fact it's even more disturbing, now it's not even flashing, it's just always on)
BTW I also had Abnormal Heart Rate Alerts enabled, but disabling it didn't turn off the green LED
