Coming from Epix 2. Why you have to start first an activity to check the maps. why the watch cant trigger the gps after opening the map? really silly....
So, how you open the maps? Lets say you are inside and want to see the map, then you open from toolbox or via shortcut the map. When indoit like that, the watch tells me always to go first to an activity…
Open the list of activities ie Run, Walk, Map, Navigation and select Map...that's it, surely?
www8.garmin.com/.../GUID-94A53DF6-163B-468F-945D-557D3EB5F24F.html I only need step one ie open Map & it…
Can you explain my point as in not following, although did post before on similar issues
Mine searches for gps when I open Map, albeit much slower to get a gps fix oddly
So, how you open the maps? Lets say you are inside and want to see the map, then you open from toolbox or via shortcut the map. When indoit like that, the watch tells me always to go first to an activity... Maybe i am doing something wrong?
www8.garmin.com/.../GUID-94A53DF6-163B-468F-945D-557D3EB5F24F.html I only need step one ie open Map & it loads my map & gets a gps fix shortly after
Apparently you didnt get my point, anyway thanks for your time!
Thanks a lot for your answer. Maybe it was a mistake to compare epix 2 with this watch, since its a totally different sw base. I can live with that solution you and the others provided.
