955 vs 965
Perhaps I am wrong, but the 955 and 965 seem to share the same internal guts. Except for the different screen and a larger housing for a slightly bigger battery to compensate for the screen change.
They both seem to have the same sensor.  Less than a year between them so definitely not a full redesign, seems more likely a cost savings measure or supply chain problem with the screen for the 945.
When I saw it I got excited it might be a sensor upgrade or at least add the ECG found on the Venu 2 Plus form last year (sometimes the mic and speaker on the Venu 2 Plus would be nice to for a quick response without grabbing my phone especially if it worked over an LTE/5G model).
At least with no internal changes to the unit, it can run the same software as the 955, which is already deep into the bug fixes (which often take over a year to get stable), though as history has shown there will likely be something purely software that the 965 will have or get that the 955 won't.
I was surprised that with all of the battery times they list on the page (with the broken battery details link), not a single time for all day Ox and/or with always on screen. I know the 945 gets about 1/3rd its battery life with the always on Ox sensor enabled. Though even with it disabled it never comes close to advertised.
Anyone have thoughts or more info?
  • Garmin should update this specs with each new firmware versions...
  • That's a good point about using the 965 on a bike...AOD is going to be dimmer and people who owned the Epix complained about that. I don't think a solution was ever found.
  • Elbo have you personally ever tried garmin MIP  vs AMOLED? Side by side? In wide variety of activities and lighting conditions? Because I have. I own EPIX and forerunner 945LTE. And from my own personal experience (having owned almost every forerunner ever made and running 2000 miles per year) the AMOLED is overall better. I will accept your fanboy accusation IF you’ve personally tried this side by side comparison while running.
    No, I haven’t. That’s why I said “it worries me”
    I do think amoled can be bright enough.
    I do know the arm gesture doesn’t work 100%. (Like I said, that’s also a problem with mips in the dark, I run more in the sun than in the dark)
    Then there is the sunglasses issue, someone mentioned. Do you run with sunglasses?
    I do value different experiences. That helps.
    And there is my opinion. Amoled adds prettynes. But nothing more. I don’t need pretty for my training/navigation. But it does make the watch more expensive. Price is a fact. Need for a prettier screen is an opinion.
  • If you haven't tried it, but are interested, then take heart at what msquared2 has said! That's good news! We all basically have the option of two almost identical watches but with different screens (once the software updates go through).
    It's a little frustrating to see people crying about things they don't actually want.
  • It's a little frustrating to see people crying about things they don't actually want.
    Garmin is looking for ways to make watches more expensive because they make more money with expensive watches.
    I think adding amoled doesn’t make a sportwatch better, but it makes it more expensive. But I fear in 1 or 2 years time there isn’t a cheaper screen option any more.
    With smartwatches or lifestyle watches, line the fenix series, with a amoled screen I have no problem at all.
    I see pictures that worries me. (I shared the link, to a highly respected dutch technical review site, I value that more than some yt gadgetblogger)
    I hear people telling with sunglasses is difficult to read
    I hear people saying for running it’s ok, for cycling it’s difficult to read.
    I hear dcrainmaker saying on sunny days in forest the lightsensor is struggeling and it takes sometimes long before the screen is at it brightest.
    And I hear people saying they have no problem at all. But they never say their use case.
    My use case is running in the forest, with sunglasses and I use it for cycling.
  • I personally use the watch for running at night and indoor cycling during winters and I have had not any major issues with the MIP screens (I just click and turn illumination on), however during springs and summers I use the watch for outdoor running, cycling and hiking in very bright sunlight and an AMOLED will be an issue for me.
  • As has been mentioned a few times AMOLED is a problem for cycling if you use it on your handle bar with a QR adapter because you can't activate the full brightness with a flick of the wrist. You can still tap it though but it's an annoyance. If you wear it on your wrist you could remove your hand from the handlebar but not always safe to do that.
    For cycling you can't beat a "cheap" dedicated device like the Edge 530 that will "true-up" with the forerunners.
  • I've used the Epix 2 and now the Venu 2 in full sunshine and legibility has never been a problem.
