Since last software version update some 2 weeks ago or so, there are random reboots of device without following a clear pattern.
By touching the touchscreen or pressing a button.
We have a fix for this issue in the 27.09 software bundle, which is currently available. Updating your watch to this version should solve this issue.
If you install the latest software and are still experiencing…
I updated my software to 26.08, and since then I have had 2 crashes with reboots during swim workouts. In both cases I was using drill mode and pressed the lap button to conclude, whereby it froze and…
After I spent time with support, engineering said they found the bug, will be fixing it, but no timeline on release.
A workaround for drills I found is to limit your drills to less the 3 minutes. Basically…
Received this from garmin for my 965. Should probably apply to the 955 also.
If you install the latest software and are still experiencing reboots or crashes, please create a new thread. Thank you!
