I think this started with 22.18 (or maybe the version before), but all of a sudden elevation gain is way off, like ~300m instead of ~60m.
Never had any issues before.
Had similar issue. Elevation was off most of the time. Activities with the same start/end would have over 200 meters difference between ascent and descent and even activities on flat courses would show…
Elevation has been ALWAYS off since I have FR955 from day 1.
It's because altimeter is influenced from temperature. Here it's winter and when I start a run the altimeter immedeately jumps 50m above actual…
A quick comparison. On the top a run during summer, on the bottom a run in winter. Same roads, it's a round-track I use for 90% of my trainings, you can see between red lines a single "lap" of 2250m.…
I've been having problems recording my elevation gain for several weeks. It always shows a much higher reading than my actual elevation gain. This happens with all apps: trail running, cycling, etc. There's a difference of around 100 meters. I've tried resetting and changing the way GPS detects, and it remains the same. Software version: 22.24
