Watch 955 solar which you'd think could handle the sun keeps freezing in 28oc temperature, has frozen twice hard reset gets it back working again but surely shouldn't be happening?
sound fun to have something freeze in the heat :-)
I'e had my 965 in higher temps than that when in Cyprus recently (mid to high 30's) and it was ok
Mine has been replaced under warranty because of that. Especially because have solar version.
Call Support / Chat with Support and they should be able to assist - if you are in the USA make sure to use the option that they send one against a deposit so you are not without a unit. You get the deposit…
Call Support / Chat with Support and they should be able to assist - if you are in the USA make sure to use the option that they send one against a deposit so you are not without a unit. You get the deposit back when you return the old unit.
Also read this
forums.garmin.com/.../some-advice-before-upgrading-replacing-a-watch-or-a-hard-reset
