My 955 detect the HRM but it doesn't show it in order to pair it - what can I do?
Is it new? I have the same strap and not had any issues. Try soft reset the watch (hold light button until power off, then power on). Also maybe try removing the HRM battery and putting it back in (or replace battery).
You can add the HRM to Garmin connect, you will be able to check firmware/update etc.
Already connected to Garmin Connect - FW is good. Will try to shut down the watch - yes, the strap is new, got it paired to my bike computer (520) but the watch is where the issue resides. So the watch power off - power on worked! Finally could see the HRM on the list of sensors! Thank you!
