I have tried to add a weather location and it rarely is able to find a result. I've tried airport 3 or 4 letter codes. Even tried New York and New York City did not appear? Not critical but strange. Advice?
Out of curiosity: are you more than 1500-2000Km away from New York?
I was finally able to find locations near me to take as reference, maybe this thread can help you:
forums.garmin.com/.../multi-location…
Try searching for a nearby airport if it is at a close distance from your location. Don't type all the letters of the name, try a few letters of its main public name and wait for the results.
Remember…
OK, was able to add nearby locations. Thanks!
Same here. Search by city won't work, also won't work by Postal Code, Airport Codes, States, etc, everything results in: "No Results Found". Also can't found the option about weather settings (fixed location, etc) on GCM :(
forums.garmin.com/.../multi-location-weather
Yes I am a long way from NYC but I am struggling to even get decent size, nearby cities to pop up.
Remember that when the clock says "No Results Found" if the circle is still spinning the search is still not finished and it may take several tens of seconds until the circle disappears and it really stops searching, at least in my experience.
