Hey!
I have the following problem on all my forerunner (955 + 265) watches in combinations with my FritzBox 7490 (same on a no name router of a friend):
When I try to connect to my Wifi, the SSID is not found at all. Others are, but not mine, although I'm just next to the router. WPA-mode on my FritzBox is set to "WPA2 + WPA3".
Once I set the WPA-Mode to "WPA + WPA2" the SSID is found on my Forerunners and I can connect to it.
However, I would like to keep it on "WPA2 + WPA3" as I have many devices already that can use WPA 3.
Is it normal that Garmin devices cannot find the Wifi-SSID at all if "WPA2 + WPA3" is on?? I guess they're not supporting WPA3, but I expected them to just use WPA2...
Curious if I'm the only one running in that same issue...
