This update, version 15.15, is a Release Candidate. "Release Candidate" means that this exact software version is planned to “Go Live” as a public update as long as no critical issues are observed. All copies of version 15.15 will be identical, so there are no differences in functionality whether you install version 15.15 as a Public Release Candidate or wait for the update to be a Live public update.
As a member of the Public Beta program, this update will be automatically delivered to your watch through GCM. Please note that GCM will check for an available update once every 24 hours, and after that it may take several hours for the update to finish transferring and be available on your watch to install.
Changes since version 15.12
- Adds support for accessing a cycling event’s associated power guide from the race widget.
- Improves the wording used for cycling daily suggested workouts.
- Adds support for showing the course point name on course point toasts.
- Adds support for the battery life remaining in days field on CIQ watch faces.
- Fixes an issue where icons were not displayed properly on watch faces with white backgrounds.
- Fixes an issue that could cause a flat line graph for heat acclimation.
- Fixes an issue that could cause sleep data and HRV not to be calculated overnight.
- Fixes an issue where the map orientation could change from track up to north up when panning or zooming.
- Fixes an issue that could cause segments not to be ended correctly.
- Fixes an issue where the calendar glance could show an all-day event as scheduled one day ahead of the correct day.
- Fixes an issue where images used on the Virtual Partner page were cut off.
- Fixes an issue that could cause the stopwatch not to sound an alert even though alert tones are enabled.
- Fixes other minor issues.
