Issue: Interval workout from VDOT using Track mode and the rest/recovery in between reps is automatically skipped
Issue started with Beta 14.08 but 14.13 seems to have the same issue. Have a interval workout sync'd from VDOT, 8X800s with 2min rest. After the first 800, the 2min rest/recovery seemed to be skipped and went straight into the next 800 rep.
  • Same here. With workouts imported from my fenix 6 pro and newly created ones.
  • I have the same issue! It totally screwed my interval workout. Luckily it was a 200/200, and I was on a track, so it was easy to know where to start and finish each interval. What is the solution? Should I leave the beta program?
  • See this and see what the near end posts say.
    I think this is the same issue
    forums.garmin.com/.../1576672
  • As pointed out this bug was already reported. Still crazy that after so many weeks such a fundamental issue in a running watch is still to be sorted. The rumored upcoming version is still to be seeing (but honestly should at least be available under the beta program!).
    Fingers crossed...
  • I got the same issues with 14.17 and I send it back to down grade to 13.23 the factory default.  However, it turns out the strip is totally wrong.  I am 1.82m tall and my 955 says my stride is 3.12m long.  Even better than any elite runner of the World.  Also, it says I move 100m during the rest time.  I mean this function is not working from day ONE of the release day.
    When you buy a new car, you will expect all the functions to be working.  You won't accept an agent tell you "sorry, due to the software problem you can not use gear 1.  But the rests are all working.  So happy driving"    Track Run and Structured Interval Trains are the most FUNDAMENTAL things of running.  If Garmin takes that seriously, they should really take time to test before releasing.
  • It used to work okay for me... then one of the updates just broke the whole thing... I don't care a lot about some of the whistles that this watch has but the basics do need to work well...
  • I could not agree more!
  • Hi,
    both yesterday and today (and also in the past) in the programming of structured workouts the recovery phase was completely skipped in one of the repetitions to be performed 5 times. In today's case where programming was quite simple after the first 1000 mt. at a fast pace the recovery started without indicating the remaining time before the next restart. I then interrupted the recording which was completely wrong, in fact it indicated 2200 meters and the average pace was (1'32"/Km)...
    I would like to insert the .fit file of the two above mentioned activities as well a screenshot of the related pre-programmed structured workouts but I'm don't know how to attach it.
    Alex
