I turned on airplane mode and started exercising, but the watch was still connected to my polar h10 using ANT+.
12.09 update:
I turned on airplane mode, and both the watch face and my headphones showed that the connection remained open。
12.09 update:
Airplane mode should disable transmission, but when connecting to an external HR strap, the watch is just receiving.
You assume that I turn on airplane mode to save power.
In fact, I just wanted to compare the heart rate of the watch and the heart rate of the HR band, and it was not until I finished the exercise that…
When the user turns on airplane mode, the user wants the phone to be able to cut off any connecti
That depends on the user. I turn on airplane mode when I want to turn off any transmission…
Yes I think that is how it is intended. Turn on BT when activity starts. When I look at the API as a developer it is not possible to turn of BT but only connect to existing linked devices (HRM, etc).
But I would expect it to when activity is finished that it turns off BT after a certain amount of time (For Syncronization reasons).
You should try to report it as a bug if it does not turn off.
the rule was that ANT+ is always active because ANT+ can only receive data not send anything.
ANT+ can be bidirectional. For instance, it's the only way the RD Pod can receive firmware updates.
how to report this as a bug? I tought these post are report itself, or there is another way? thanks
