I turned on airplane mode and started exercising, but the watch was still connected to my polar h10 using ANT+.
12.09 update:
I turned on airplane mode, and both the watch face and my headphones showed that the connection remained open。
12.09 update:
Airplane mode should disable transmission, but when connecting to an external HR strap, the watch is just receiving.
You assume that I turn on airplane mode to save power.
In fact, I just wanted to compare the heart rate of the watch and the heart rate of the HR band, and it was not until I finished the exercise that…
When the user turns on airplane mode, the user wants the phone to be able to cut off any connecti
That depends on the user. I turn on airplane mode when I want to turn off any transmission…
What FW is on the watch (sorry if I missed that in all the posts? I am on 14.13 currently) Also did you do a soft reset recently at all (holding in light button until the watch turns off completely, then restarting after a few seconds) Sometimes that seems to sort minor issues after a FW update.
I am not going to comment more on what is wireless :) - But I can comment om this.
To My Knowledge the decision was orginally that if you start an activity like RUN where you are using an external heartrate monitor (Bluetooth). Then it will try to use that sensor, but only on that activity. This means that If you do not generally add a bluetooth devices in settings - but on activity settings it should turn off bluetooth when the activity is finished.
You probably remember the issues where the watch used a LOT of battery. The reason for that was that it it did not disconnect the bluetooth sensor when the activity was finished.
Also a few months back there was an issue on android devices that after a sync using garmin connect - the bluetooth connection wasy not removed - hence the battery-usage. This was fixed in a garmin connect update.
A few months back in one of the previous FW releases there was a bug that was related to Android users only (High battery usage) because the garmin connect app didn't release the bluetooth connection after a sync.
Garmin might have re-introduced this problem if you are still experience high battery usage.
Yip I see if I activate Run as example whilst in Airplane mode BT etc . although strangely enough not ANT for the HRM :-) , and exiting the activity then does not shut off BT , although out of activity and in Airplane mode still.
Oh life is such fun all these little nuances within things :-)
Not that i ever saw the need to use Airplane mode as of now but interesting to see what happens...
How I understood it from last years developer conference (or perhaps is was from the year before that) - the rule was that ANT+ is always active because ANT+ can only receive data not send anything.
Also in the API there is no option of turning ANT+ off.
( https://developer.garmin.com/connect-iq/api-docs/Toybox/Ant.html )
I had this problem since 3 version back now (14:13) but seems getting worse, or maybe I'm giving him more attention then before. I had tried a soft reset, i'll retry it and see what happen.
This morning it turned ON bluetooth after a few hours I was awake...
