Accute load has stopped updating on the 955. Still get a load value for an activity but no update to acute load and load focus values gone.
Still working fine and up to date on the 945.
Yeah, Apparently there is new issue related to it. That what Rubik posted and https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-955-series/317150/todays-exercise-load-attributed-to-following-day
If you can't use the Garmin Express software (on PC/Mac) you could try the following.
Make sure you have already configured WiFi sync on the FR955.
Long press the Light button (upper left) and select the sync action. When it starts syncing, swipe up or press the Down (bottom left) button to change from Bluetooth sync to WiFi sync.
Wait a few minutes. If it does download an update, the file may be large.
A bit later, hold the Up (middle left) button to get the menu, then press Up again to get System, Start (upper right) to select it, then Up again twice, then Start to select Software Updates. (It's faster with the buttons than using touch swipes.)
You MAY be offered the software update as one of the options at this point.
