Battery consumption: initial observations?
i know it's probably way to early to start this discussion, but i figure crowd sourcing may yield some insights. in short, after very disappointing battery use, in particular smart watch mode endurance on my 945LTE, i have been hyperaware of how much battery use my 955 Solar is using. just overnight (8-9 hours), i was surprised to see it dropped 3-4%. it may be that the battery gauge is poorly calibrated, but so far, even though one would guess it has a larger battery than the 945LTE, i'm finding consumption not very different.
on the positive side, for my one activity so far, a 70 minute run with Multiband+All satellites, i used up 6% which right on target with spec. (basically zero sun since i ran before and just as the sun was coming up).
i'd love to hear other people's impressions and experiences as some of you have had the watch (just a bit ;) ) longer.
  • I have Garmin Forerunner 955 Solar and had problems with battery life, ~2% drop / hour after run with HRM Pro. To prevent that I had to restart the watch after each run.
    Last week I have updated the watch with 12.23 and the problem is gone.
  • Anyone else still have problems? I’m on version 12.27, have to keep bluetooth off or else I lose 1-2% battery per hour. It’s really frustrating. I’ve tried all the usual fixes from here and Reddit.
  • I have 13.22 and battery lasts max. 5 days even if I don't do any training. Wifi off, pulse-ox off, notifications off, brightness 20%. Actually notifications are off, because I can't get them to work at all.
  • Same here. 1% per hour down. I tried everything(different watch faces, BT off, Wifi off, reset, …) still no improvement. Frustrating!
  • I have updated the watch to Software Version 13.22 and the problem disappeared.
  • Battery consumption is for the most part great. In a multiband GPS activity it drains around 5% an hour as advertised (this is regardless of whether course navigation is being used). In a timed non-GPS activity it drains around 1% an hour. During sleep it drains between 1 and 2%. Smartwatch mode seems to also be roughly in line with the advertised value.
    However, there is a battery drain bug with 13.22. I haven't been able to pinpoint what causes it but it seems to coincide with the touchscreen lag issue that a lot of people have reported. The issue will cause the battery to drain 2-3x faster in smartwatch/sleep mode.
  • I am on 13.22 and I took my watch off charge at 9PM and by 2 PM the next day I have lost 10% with no activities at all. This can't be right and never used to be like this when I first got the watch a few days ago.
  • Did you power off the device after your FW upgrade? if not, then it is the main reason for the increased power usage.
  • I didnt do it straight away but did last week. Still draining fast.
  • For me, it helps to turn on and off the activity in the indoor pool, even after the bike activity, I do this. it seems that the gps is turned off and syncing with the phone stops
