Some time ago, when I do a triathlon, during the transition the GPS is deactivated and in the map you only see a little dot. Any idea about how can be fixed that?
Thanks!
Thanks!
All,
Please see our recently released beta software for a fix addressing this report. If you prefer to not install this beta software, we hope to be rolling out a public software update soon, though I…
I have also experienced the same problem since a month ago after some update. It doesn't show the distance during transition, and then adds it to the run at the very beginning. So for example, if you've…
Good to know. I had similar problem last weekend no GPS during transition and an insane pace for the first running kilometer. I was wondering why the first km was so much off.
Hi, similar problem here. I did a Triathlon last weekend and set the watch to Multi-Sport. My old FR 935 recorded my way through the transition zones, the 945 does not. Additionally the first kilometer of the run part was recorded incorrect, the pace was totally off and the 1k autolap was already taken at around 700 meters!
Any news on that problem?
I have also experienced the same problem since a month ago after some update. It doesn't show the distance during transition, and then adds it to the run at the very beginning. So for example, if you've covered 500m during T2 and then start the run, suddenly you begin with 500m already, which messes the avg. pace completely.
I just had the exact same problem racing this past weekend. On may 1st I raced and triathlon mode worked fine, giving me a map of my transitions and Mike splits on the run. I changed nothing between that race and the 2 I just did this past weekend. Has anyone at garmin addressed this issue? Any fixes?
For me it changed after an update between May 7th (worked well with GPS map of transitions) and May 15th (no GPS in T1/T2). After that there was another software update where I hoped it would be solved but unfortunately not.
I wrote to the support team but haven't got an answer yet. Will follow up if I know more.
