Hi All
I am using F945 while cycling. Normally after I finish, I sync with Garmin Connect on my Smartphone (Samsung S10) and the data is recorded in the calendar, accruing to the challenges I subscribe to.
Now I use an indoor cycling device and use Rouvy App with ANT+ connection with Garmin speed and cadence sensors. Rouvy App records all the information when performing a virtual journey. I export data from Rouvy (in FIT format) and import it into Garmin Connect and it's OK.
The data is logged in the activity calendar, but it doesn't add up to the cycling challenge for the month I signed up for. VO2 values, exercise intensity were also not recorded.
Are those values not recorded by the F945 so Garmin Connect doesn't count?
