Just had a run with my 945. GPS was way off during the run, I mean about 50-100 meters off reality during the whole route.
Has anyone else had this today? Using GPS+Glonass setting.
Janne / Finland
Janne / Finland
I have done a few more experiments and think I have worked out what is going on.
Before going for a run today I connected to GC on my PC and did a sync. I verified the CPE had downloaded correctly by checking…
Not impacting everyone, but it is a system-wide issue impacting multiple device types, not only Garmin devices.
I've just done some work today, and you can take the GPX file and make a manual adjustment to the lon / lat and correct it.
It would be too labour intensive, so I made a small python file to make the…
Ha, definitely 2020 is to be blamed for many things. It even screwed up 2021. LOL.
Yep, climbing metrics for a run that should be up and down around 20m each way gave me a constant climb of 90+m!
Your source for leap second for 2020? https://www.timeanddate.com/time/leapseconds.html
On the Fenix side:
https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/250026/known-issue---gps-accuracy-issues-starting-january-1st-2021/1189900#1189900
So if someone manages to get it CURRENT, could you share your CPE.bin? :D
Yep, but it is how it is :(
Tested that with:
- Removed CPE.bin
- Turned watch off
- Turned watch on
- Hike, wait for GPS
- Start, wait for 5min.
Now I have new CPE.bin but it's still 2kb and CPE: Expired.
So that workaround doesn't seem to work. So waiting for GPS firmware update.
It seems 745 owers might be the lucky ones to grab a working CPE file from https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/250026/known-issue---gps-accuracy-issues-starting-january-1st-2021/1189677#1189677.
