Hi, I bought my 945 approx. 3 months ago. In the beginning everything worked fine, but since 3 or 4 weeks the watch randomly freezes, displaying a blue triangle. Most of the time I see this in the morning - so I guess it could be caused by a sync or an automatic update task running at night. Unfortunately the only solution then is to do a hard-reset. Sometimes it then comes back normally, but sometimes it just displays the triangle again after the restart. In these cases I repeat the hard reset a couple of times, and then the watch comes up with the initial setup routine.
I already went through this initial setup routine several times as well as a complete factory reset via the menu directly on the watch, but after one or two days of normal operation the problem returns.
Any suggestions? Many thanks!
