Since my runs are getting longer, I've been using the maps/navigation on my Forerunner 945 a lot in the past couple of months. I've been plotting many different courses to make sure to get the proper distances. Also I'm experimenting with different routes (usualy trying to get the flattest route possible ).
The thing is, when using a saved route, about 25% (might be more) of the time I just won't get a turn notification. When going to the map, It will show a turn much farther away (say, like in 800 meters), even though there are one or two other turns in between. I thought this might be a map problem so I downloaded another map of my region. No luck, still missing a lot of turn notifications. unfortunately this means that on many intersection I've to check the maps if I have to turn or not. This actualy defeats the whole purpose of TBT navigation.
I think it's always the same intersections that do not prompt a turn notification, but I'm not a 100% sure whether this is true or just a coincidence.
All my maps as well as the firmware are up to date. Anyone else experiencing the same problems?
