updated to 5.20 this week and battery drain significantly higher. 30% pd with no activity, WiFi off, OHRM on and SPO2 on during sleep only.
anybody else experiencing this? Any advice?
Can't confirm any increased battery drain with FW 5.30 (shortly relased after 5.20).
However I always start from scratch after each FW update, performing a full reset inc. user data on the watch.
Usually from my experience the worst battery hogs are:
- badly programmed watch faces (stick with the original Garmin one for a couple of days to observe battery consumption)
- badly programmed apps from 3rd party suppliers
- radios: keep both, WiFi and Bluetooth off and compare battery discharge
- PulseOx: your setting (only during sleep) should be just fine
Perform a full reset and do not install ANY watchface or app for one week to observe battery behaviour. If everything is ok, try adding one new item at a time to identify the problem.
