My forerunner is on 2.8, EU version
I tried both with Garmin connect on windows and on iOS but it says that 2.8 is the latest version while I know we are already at 3.0 and above.
Any idea how to fix it?
Maybe (be aware of this) you can perform a manual update to some beta firmware (all beta firmware are manually updated), like the one described here (from 2.8 to 3.08)
https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-945/193633/forerunner-945-beta-sw-3-08-is-now-available
This update has the advantage that you can revert it back to 2.8.
Here some future possibilities:
1- After the update maybe you can update it normally to a new version (I am just guessing).
2- If the update works, but #1 doesn't maybe you can repeat the original process with newer beta firmware like this (3.77):
https://www8.garmin.com/support/download_details.jsp?id=14933
So, in the end, you will be hopping between beta versions in order to be (almost) updated.
Disclaimer: If user tess is right (that you have an APAC watch) is up your risk to test this solution (I don't know if beta firmware are compatible with APAC watches... I would say yes, why not? but I didn't test it).
Beta software is not recommended for APAC watches.
found how to check APAC ror ROW version
new-945-stuck-on-v2-40-software-will-not-update-to-v2-50
APAC or ROW
on your device in the GARMIN folder is a file called garmindevice.xml
open this file with a text exditor or an xml capable browser and search for
<PartNumber>006-B3113-00</PartNumber>
when you find this text you have a ROW device
when not you have a APAC device and their firmware versions are behind but stable ones
update recap:
ROW <PartNumber>006-B3113-00</PartNumber>
APAC <PartNumber>006-B3441-00</PartNumber>
happy sporting
happy & safe sporting
it could trigger GE to download the ROW firmware
after a filecheck the watch is not going to install it
what stops you from trying and being the first to succeed ?
have not seen any succesful row > apac or apac > row transition
