I read on another post that it will only connect to open networks. My Edge 530 connects with hidden networks just fine as long as I define them ahead of time. Why is the 945 different?
Hidden SSIDs are not a good thing for low power devices as instead of just passively listening to beacons from the Access Points containing the netork name, the device has to actively query the APs to…
The last Garmin watch that was able to connect with a hidden SSID was the 630 for me (if I remember correctly). I remember when I got my F5/935 I had to make the SSID visible. Since then I have it like…
The last Garmin watch that was able to connect with a hidden SSID was the 630 for me (if I remember correctly). I remember when I got my F5/935 I had to make the SSID visible. Since then I have it like that thus I can't tell you if it worked again in between.
There have been lengthy discussions regarding this behavior (maybe by design?) but at the end it's no protection anyway. Someone who want's to fiddle with your WLan will for sure not be stopped by a hidden SSID.
Hidden SSIDs are not a good thing for low power devices as instead of just passively listening to beacons from the Access Points containing the netork name, the device has to actively query the APs to check if they are part of that network.
It's also a privacy issue as it makes you trackable as your portable device will constantly broadcast the network name when it's searching for those hiddent network.
Overall a BAD design, please avoid using hidden networks.
