Lactate threshold test not working - always "workout ended, threshold not found"
Just wondering what I'm doing wrong - I have had 4 attempts to get a successful lactate threshold test, and each one gives me "workout ended, threshold not found"
watch is 945 rev A v2.80
Garmin HR-RUN strap
Am doing them on grass athletics track
I am pretty much staying within each interval's HR range
It doesn't consistently guide me through the same intervals though -
HR max set at 170 - 2x 4min, 2x 3min - "threshold not found"
HR max set at default (165) - 3x 4min, 2x 3min - "threshold not found"
HR max lowered to 160 - 2x 4min, 1x 3min - "threshold not found"
    0 Former Member over 5 years ago
    So you don't have a clue as to what your maximum heart rate is? Maybe your setting is way too low?
    I'm almost 66 with 190 bpm for HR max and my threshold test had me running 4 min @ 155 bpm, 4 min @ 165 bpm and then stopped at 3 min @ 175 bpm when it said it detected the threshold.
  • 66 with 190 - wow! well the old 220-age has me at 165 - but that's why i wanted to do the test, to find out more accurately what it is. you suggesting bumping it up further than the 170 I tried? will give it a go and see what happens - thanks
    0 Former Member over 5 years ago in reply to DrumPhil
    HRmax is best tested, not calculated. If your healthy do a good warm up, then all-out intervals and see at which HR you end up. Make sure not to use a single beat as HRmax but the one for a few seconds. My calculated one is 172, the real one 186. With better technical skills HRmax increased over the last years.
    I have never been close to that calculation. Mine has come by actual that has been obtained, so it may be a little low yet as everything I've read tells me true max is really, really , really hard to obtain... I looked in my Connect/watch settings this morning and see my Max now at 194. I guess it has changed over time.
    As @5082041 mentions, best not to guess...
  • well, i'm trying not to guess, which is why i'm doing the lactate threshold test. i just haven't been able to make it successful. once i have, won't the watch set my max hr accordingly (per some formula)?
  • I have the same problem.
    Eventually sometimes I get a threshold value, but the most of the time I get the same as you: "workout ended, threshold not found". The last time I tried on a track, and it couldn't find a threshold even if I was always in the heart rate green zone. I gave up and I don't do threshold test any more. When I do my training sessions, I wear sometimes the chest strap and I hope that it updates the threshold value, but it never happens. Now I have a threshold value two months old.
    There is no working formula for HRmax, formula equals guessing. HRmax you reach is anyway sports specific. Either chance it and set it to 190 or better test it. It's even better to invest a few bucks and have it tested in a lab, then you get LT1, LT2 and HRmax and the real VO2max all at once.
    Hello,
    i do have the same problem - now!
    In September i did the test. And it works well.
    1. Step Target 131bpm
    2. Step Target 144bpm
    3. Step Target 153bpm
    4. Step Target 162bpm and in 3/4 i couldn't hold the pace anymore, test finished
    Threshold Puls: 155bpm with 4:37min/km Pace
    all good.
    Test September 2019
    Today after a lot training, i feel and i know i am much more fit:
    5. Step Target 171bpm i couldn't hold the pace anymore, test finished
    BUT THIS TIME: COUDN´T FIND A THRESHOLD :-(
    Test April 2020 - failed :-(
  • Same problem here. It was working in November.
    0 Former Member over 5 years ago in reply to danpinho
    I tried a LT test in Jan and was unable to even get close and felt like I wasn't really rested enough to perform as was needed. Later in Fed (About a month later) I did a LT test and it worked.  9:23 min/mi @ 173 bpm
    1 Target 145 bpm
    2 Target 160 bpm
    3 Target 169 bpm
    4 Target 179 bpm
    LT Test
    I guess you have to meet certain criteria
