since FW 2.80 my battery drain goes up to 50% more as before, haven't changed anything on my setup!
before FW 2.80 for 24h arround 7-8%
now with FW 2.80 in 12 hours the same, lost 8%
Anyone experiencing high battery drain should start with a hard reset (holding the power button for up to 15 seconds). If this does not resolve the issue, more information will likely be needed from you…
hello ,
what i can tell for sure is that currently (with only spo2 activated during night and daily steps tracking) the battery life of the 945 is way worse compared to the 935. with 1-2 workouts/ day with…
Can't we have statement from Garmin if they have noted that there is an issue with battery drain and they plan to solve it?
what do you think about following?
Garmin make the possibility so that the user can configure how often they want to measure the Pulse OX, so every User have more control over it.
for example, User A configure he wants to measure every hour the Pulse OX, User B wants to measure every 30 minutes and User C only every 6 hour or so?
More or less have the User more control of the Battery drain for Pulse OX measurement?
think it's a win/win Situation for both sides?
I already tried this, and although the battery is less consumed, I see that the consumption is high, regularly I had 4% per day, HR + SPOX. The difference I see is that it now registers SPOX all night, more than 4 hours, the manual says it only registers 4 hours but now it does it for longer.
I made an observation but it's for sure no solution yet, nor a statistics. For everyone who has problems with the battery, please try the following: please don't unplug the watch immediately after it's showing 100 percent but let it plugged for another hour. I observed that the battery drain is then very low at the beginning of the discharge cycle. Maybe there is a problem when the battery is marked as full during charging. As I said only an observation.
