Ant+ connection Unstable problem
I purchased fr945 through Garmin Korea (Korean version)
The firmware has been updated from 2.4 to 2.6, but the ANT + connection is still unstable.
Both RD POD & HRM-RUN are disconnected randomly while I am running.
Often I think that the hardware is normal because sometimes I work normally until I finish my workout. (The conclusion is a software error)
ERROR case
https://connect.garmin.com/modern/activity/3854369799?share_unique_id=14
https://connect.garmin.com/modern/activity/3837854482?share_unique_id=18
https://connect.garmin.com/modern/activity/3789213467?share_unique_id=22
Normal case
https://connect.garmin.com/modern/activity/3850904032?share_unique_id=16
https://connect.garmin.com/modern/activity/3824615460?share_unique_id=20
  • You are using HRM-Run and RD Pod together, or you have a same problem using HRM-Run or RD Pod?
  • The RD-POD connection was unstable at first use 945, so I tested it with HRM-RUN (replace with new battery, 630 bundle), but the same problem occurred.
    Right now I am only using RD-POD.
    I have exactly the same issue. I tried to connect my FR945 with Hrm Run (red one). It connects and disconnects continously. Connecting with Hrm Swim is also facing problems. At the end of my swim session i have to try several times to connect them and download the stored data. Finaly i have the same problem (connect and disconect during cycling session) with my Tacx trainer. With my previous watches 920xt and FR 935 i never had such issues. Not to mention  that the connection between my FR945 and my mobile is horrible.
  • you tried to switch off the watch before?
    what Firmware? mean, gone something wrong during firmware update?
    what versions do you have on the watch?
    press left middle button -> System -> Info:
    GPS: 2.30
    WiFi: 2.60
    CIQ: 3.0.11
    BMX: 04.8
    WHR: 20.04.12
    ANT/BLE/BT: 3.60 <- especially this one?
    Sensor Hub: 2.20
    0 Former Member in reply to f|33tStA
    GPS : 2.30
    WiFi : 2.60
    CiQ : 3.1.0
    BMX : 0.4.8
    WHR : 20.04.32
    ANT/BLE/BT : 3.60
    Sensor Hub : 2.32
    I turned my watch on and off several times, my mobile the samethe result is always the same.
    Now using 2.64 Beta. The same issues with oficial 2.50
  • WHR : 20.04.32
    Sensor Hub : 2.32
    both version coming with Beta 2.64? EDITH: seems so, cause you have CIQ3.1.0
    i haven't any probs with official 2.50, i use Tacx Neo2 but cadence only, Vector 3 and HRM-Run on my indoor training sessions, the rest of Tacx Neo2 is connected to Zwift with Vector 3 and no probs.
    HRM-Run only with running an strenght training, no probs
    Outdoor cycling with HRM Run and Vector 3 no probs at all
    In your case i think a Watch Reset make sense (i hate this option), if you have the same probs again try to replace the watch with contact local Garmin Support
    EDITH2: or try to contact Garmin Beta Team, now you have the option, cause of the installation!
    I had the exact same problem.  My HRM and footpod dropped out randomly but synchronized. I got a replacement from garmin which fixed all problems
