I am using the Garmin Coach HM training program and would like to use the turn-by-turn navigation for the same runs. Is it possible to combine a training with navigation for the same activity?
Yes it is. Start the coach generated training workout then scroll through to the map screen and load your course.
I don’t use Garmin Coach, but on the 935 I’ve used both programmed workouts and navigation for the same activity. If you’re in the Run activity (or whatever), you should be able to hold…
This can be done on a fenix 3 as well. At least with the Fenix 3HR. I did this all the time -> load a workout first, then go to options and load a course.
Intersting! I never knew that. Thanks for sharing.
On the FR735XT go to "Navigation"->"Courses". Select your course and then "Do Course". Do not start the activity, but instead back off to the menu, and then go to "Training" and then whatever you want to do. This will run a programmed workout on a selected course.
