hi all,
The satellite acquisition is really slow on my 945 be old 235. I see CPE expired. I've tried syncing with Garmin connect on my phone but still expired. Any ideas on how to fix? It's like this even after a long run.
Thanks
Steve
hi all,
Thanks
Steve
We have escalated this issue and are working on a permanent fix. There are situations where devices will show expired CPE data when this has in fact synced to the device. We apologize for the inconvenience…
Update: Wifi sync resulted in refresh of CPE.
Update 2: stil this only lasted for 1 day, the next day again "CPE expired"
Actually there currently is a problem with Garmin's GCM Sync and CPE updates. Although the watch is synced daily via GCM the CPE still expires. And I do not refer to the menu display, it really expires…
Sounds like you need to sync your device to refresh satellite location information.
What Does EPO or CPE Mean on My Garmin Fitness Watch?
Downloading GPS Satellite Location Data to a Garmin Fitness Device
Edit: sorry, guess you already tried.
Well, that's what he already tried.
SteveBUK Do you have a chance to connect to a PC with Garmin Express? Sometimes that works better than updating via BT.
I usually start a manual WiFi sync of my 945 before I go out for a run and I have no CPE issues. But this triggered sync is because I wear the 945 only for running and I want to get in-sync with the data my Fenix 5+ recorded (that's my all-day watch) before I add additional data from the 945 side.
We have escalated this issue and are working on a permanent fix. There are situations where devices will show expired CPE data when this has in fact synced to the device. We apologize for the inconvenience in the meantime. Syncing at least once every seven days will in fact refresh this data despite what the menu might say.
The sounds like the same issue I am having on my 935 with the EPO. Will the fix be for both?
